9 Bolt questions
Old Oct 6, 2003 | 03:04 PM
I RoC A Z's Avatar
Car: 1989 Camaro Iroc-Z
9 Bolt questions
Ok I have 89 Iroc with 2.77's I want to upgrade my gears. Where is a good place to buy gear for a good price? How much do set usually run i have a chanve to et 373 for 175 right now....
Also I hear 2 different stories. Do you have to buy a new posi unit for ever gear set for the 9 bolt?
I have heard yes and no's?
Comments please
Old Oct 6, 2003 | 05:23 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I don't believe you need a new posi unless your's has gone bad and is pulling one leggers, but I'm not sure there might be a difference in the series on the carriers.
175 bucks for a 3.73 9 bolt gear set is pretty good as long as it's in good condition. I bought my 3.73 gear set from Randy's ring and pinion for 190 bucks brand new (one ratio they stock).
Going from 2.77 to a 3.73 would require a new carrier I believe, series 3.
3.73 is pretty steep for a TPI if that's what your running. They usually like 3.42s a little better cause they can stay in the mid range where they make all there power.
try www.9bolt.com
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
