posi questions.
Old Oct 6, 2003 | 07:51 PM
icebird_1981's Avatar
posi questions.
i tryed searching but it gives me way to much topics. anyway today i found out that i dont have posi and i thought i did the messed up part is i just had new gear installed a 3 weeks ago i could have got it done then . anyway how big of a diffrence will it make if i get it? what does posi effect/do?? also is posi just a add on part i mean i dont need to get a diffrent type of gears or anything do i??
i no lots of question but i learn everything off this site lol.
Old Oct 7, 2003 | 11:14 PM
bonz's Avatar
Car: 89 GTA
posi
Not sure if this is what you want to know but, posi is when both wheels spin at the same time. It gives you better trackin, also makes it a little more fun. If you want posi you need a posi rear end.
Old Oct 8, 2003 | 12:54 AM
89ReDIrOcZ's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7L 350 TPI
Transmission: 700r4, Shift Kit
or u can do wat this one guy did to his eclipse and weld that **** togehter lol
Old Oct 8, 2003 | 05:30 AM
ede's Avatar
ede
with the correct series carrier all you need to do is swap a posi carrier in place of the non posi and swap the ring gear over. check back lash and you'd be all set
Old Oct 9, 2003 | 02:09 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
if your rearend is a 91 rear end like im assuming you can go cheap and get a SLP posi. It is 99$ + 12$ shipping from slponline.com
I just ordered one resently.
Old Oct 10, 2003 | 09:53 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Powertrax
Add a powertrax unit from Jegs or Summit. It won't make the differencial any stronger, but you can install it yourself without having to set the rear end gear lash again. This saves time and money. The powertrax replaces your spider gears.
But if you want a stronger rear end, you'll have to spend the money all over again anf install a new posi unit.
The stock rear end with a powertrax unit should handle a mild 350 on street tires with a girdle, and smart driving.
Old Oct 12, 2003 | 05:20 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
Re: Powertrax
I went that route before"pwertraxx" and it worked great for straight shots and was pretty tuff....but they do make noises in slow turns ...so if your looking for smooth action and no noises go with a different setup,but as I said the Powertraxx is strong and made of Zitanium the noise was the only thing that I didnt like but other than that its great
Old Oct 12, 2003 | 10:34 PM
thanks guys i am going to go with that pwertraxx unit.
KO1
16
Oct 15, 2015 05:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
