Just need a quick clarification on differentials/carriers, thanks.
Old Oct 7, 2003 | 01:26 AM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
I posted about swapping in different gears and am learning about that, but specifically, I just need a clarification on this issue.
Is a carrier equal to a differential? Like are they the same thing? Like someone says "I've got 2.73's, I want 3.73's", and someone replies "You need a 3-series carrier", does that mean he has to change out the differential itself to 3-series, and people just refer to it as a "carrier", or do you take off the cover and there is an actual piece inside the differential called the carrier that can be taken out and replaced?
Thanks!
Old Oct 7, 2003 | 05:19 AM
ede's Avatar
ede
the carrier would be the assembly under the rear cover, whjat the ring gear is bolted to
Old Oct 7, 2003 | 11:18 AM
jamesbob02's Avatar
Car: 92 Z28
Sorry, but that's kind of a vague answer for someone as clueless as me. So I switch to a 10-bolt, am I going to need a different differential and a different carrier?
MrPackstin
Oct 25, 2017 08:09 PM
MadOTC
Oct 13, 2015 04:46 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
3.8TransAM
Sep 27, 2015 08:37 PM
