Ungodly rattle sound
Recently when I put my car into reverse it makes this metal-on-metal rattling sound that disappears when I go into drive. However I've also noticed that when I come to a stop sign and the tranny downshifts it also makes that ungoldy clank sound. (it all makes the sound if I go over a brick road)
I had the car lifted and they told me that I have a broken mount on the bar that goes from the transmission to the rearend (keeps the body straight?), but they didn't know what it was or where to get it.
So im getting the part from the dealership cause AutoZone doesn'y have it. If anyone here knows what it's called please tell me cause the GM dealership here is famous for saying "You tranny is dead" from anything from an oil leak to a blown out headlight.
1989 IROC-Z 5.7L
9bolt rearend
poly tranny mount
B&M shift kit
1989 IROC-Z 5.7L
9bolt rearend
poly tranny mount
B&M shift kit
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Yep, tq arm mount... get a poly one to replace it (or if in hurry put a OEM one in). and you should be good to go again.
Engine: 383 SBC
hmm... Aftermarket ones are all one piece I believe *I'm running a rod end so I didn't upgrade from stock*
Here's a link to Jeg's tq arm bushing page.
http://www.jegs.com/cgi-bin/ncommerc...73&prmenbr=361
Here's a pic too that I linked from that page.
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
The stock rubber gaskets are 2 piece, I would change both based on the logic that if one already broke the other will soon follow. But then the urathane pieces are much better so just get one of those.
