replace rear end or rebuild?
Old Oct 8, 2003 | 02:33 PM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
im not sure what i should do about my 9 bolt rear end. both axel shafts are bent and i think my posi is slowly going as well. at this point im not sure wether its better to buy a whole new rear end or just replace the axel shafts and "try" to fix the posi later on. some where i heard that 9 bolts arent rebuildable, is this true? and does that mean i cant fix the posi? i am just recently trying to learn about the inner workings of differentials, if the inside of the differential can be fixed or replaced than im sure i can do it myself. but if i can get a new rear end for almost the same price id much rather do that, because this thing is a rusty peice of ****. what do you guys recomend i do?
Old Oct 8, 2003 | 03:18 PM
ede's Avatar
ede
do a little price shopping and i ithnk you'll find it more cost effective to replace than rebuild
Old Oct 9, 2003 | 12:07 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Most 9 bolts can be rebuilt with the proper parts (ie not just more shims!). 9 bolts are not cheap, they are much stronger than a 10 bolt and new posi units and ratios to 4.10 are available.
Miles
Old Oct 9, 2003 | 05:19 AM
Psyte's Avatar
is there an alternative to 9 and 10 bolt rear ends? whats the best and cheapest "aftermarket" rear end i can buy for this car?
Old Oct 9, 2003 | 05:30 AM
ede's Avatar
ede
best is pretty subjective, but if i were going to buy one i'd look at a 9" from moser
Old Oct 10, 2003 | 03:36 AM
Psyte's Avatar
is it at all possible i could get my axel shafts bent straight again? moser's rear ends are a little out of my price range at the moment. i can still drive around fine on the bent ones, but it feels really screwed up and i get alot of vibration at higher speeds.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
