rear end is crying
Old Oct 8, 2003 | 04:10 PM
strokedtpi's Avatar
Car: 1990 Formula 350
Engine: 5.7
rear end is crying
ok heres the deal the rear end on my 90 formy wines at certain speeds but not other.... like if im goin 50-53 i howls an whines if i bump it up to like 6 it is completely silent????wtf
i figured it was the gears im not really sure if it stillt he stock 3.23's because my speedo is a little slow and as you speed up it gradually gets worse....
any input?
thanks
Old Oct 8, 2003 | 08:37 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
sounds to me like someone put a 3.42 or 3.73 in it, or to that whereabouts, and didn't have the backlash adjusted just right, although that should wine louder as you go faster, but that's about the only thing I can think of...
Old Oct 8, 2003 | 09:46 PM
strokedtpi's Avatar
Engine: 5.7
if the backlash is off do i need to pull these gears as soon as i can or will it be okay if i jus5t leave it alone??
Old Oct 8, 2003 | 09:50 PM
Stingraye's Avatar
Car: 1986 Trans Am
Well, depends on how long the problem has been there? if it's been a long time, then the damage is probably already done, and the only worse it will get is shearing the gears, or the head off the pinion. if it just started, then the longer u drive with it like that the longer it will wear an uncorrect wear pattern into the gears, and make them weaker/more suceptible to damage. Different manufactures state different ammts of acceptible backlast, i've heard 2-6 thousands, and 4-10 thousands. But if it's been doing it for a while, and gets worse, plan on getting a new ring and pinion kinda soon, if it just started, see if someone can pull u'r cover and check the backlast on it with a dial caliper and see if it has caused damage and can still be adjusted.
Old Oct 8, 2003 | 10:59 PM
strokedtpi's Avatar
Engine: 5.7
hey thanks man ill have to see what i can get done..
eric
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
