th350 question
Old Oct 8, 2003 | 09:24 PM
icebird_1981's Avatar
th350 question
can someone tell me if there is something on a th350 tranny that needs to be adjusted. someone told me there is a modual on them, what does it controll?? also could someone tell me if the th350 sets the shiftt points based on throttle position?
Old Oct 8, 2003 | 10:09 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
a T350 uses a vacumn modulator to control shift points, the cable to the engine is only for kickdown(hence, kickdown cable), factory modulators are not adjustable, but you can get a aftermarket adjustable one that will let you adjust your shift points
Old Oct 8, 2003 | 10:14 PM
so at WOT they shift the same as normal driveing? i find when i am at WOT she shifts into 3rd so fast (couple of seconds) and dont get the rpms up in second. she only feels fast in third, or when i downshift to second at a faster speed. is this normal?
Old Oct 8, 2003 | 11:33 PM
Dave Y's Avatar
Engine: 4.3L V6
make sure the vacumnb line from the engine to the vacumn modulator is good, and make sure there is no trans fluid inside it
Old Oct 9, 2003 | 12:34 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
How do you adjust them? We have "adjustable" ones at advance where I work but I don't see how they adjust/.
Old Oct 9, 2003 | 04:15 PM
Dave Y's Avatar
Engine: 4.3L V6
you stick a small allen wrench in the vacumn port
Old Oct 14, 2003 | 03:51 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
why not just shift it manually when you want it to shift?
MustangBeater20
Oct 29, 2022 09:20 PM
LittleFranks
Sep 17, 2015 12:22 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
