clutch and flywheel ??? on T56
Old Oct 9, 2003 | 01:12 PM
MILT's Avatar
Okay here's the deal. I am installing a 2-pc RMS 350 in place of my 1-pc RMS 305. I know I need to switch the flywheel for my T56 to flywheel (# 700107), but can I use the McLeod clutch I bought (that was on the 1-pc RMS 305) or do I need a new clutch disc for the new flywheel?
If I need a new clutch, any specific models for 300hp 350 you can reccomend?
Also, is there an aluminum variant of the 700107 flywheel?
Thanks guys,
MILT
Old Oct 9, 2003 | 06:30 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
You can use the McLeod LT1 clutch with the new flywheel, just make sure it's still in good shape (plenty of meat, no hot spots) when you do the swap. If not I highly recommend the SPEC stage 3 as a replacement. There is an aluminum version of Centerforce #700107, but I don't know the part number and I think it's quite a bit more pricey.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
