how do i bleed my clutch?????
Old Oct 11, 2003 | 02:12 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
well topic says it all.. i got the pedals and hydrolics as a complete assembly.. how do i bleed it? is it just like bleeding brakes? where is the bleeder and what tools do i need to open and close it????
Old Oct 11, 2003 | 12:09 PM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
theres an allen head bolt in the top of the slave cylinder in a small tower right behind where the hydralic line attaches to the slave cyl. carefull not to over tighten though, the bolt is brass the slave cyl. is plastic. go figure. fill the resivior, pump 5-8 times, loosen the bolt, etc. just like brakes.
Old Dec 12, 2003 | 01:44 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
how long do you do this for? until fluid comes out of the bolt?
Old Dec 13, 2003 | 06:19 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
the way we do it at work, is full the master cylinder up, leave the cap off, and pump the clutch pedal, you might have to pull it up by hand because theres no pressure. make sure it comes all the way up. After you pump it for a lilttle while you should start to feel the resisance and most of the time this is all I do. Sometimes I pump the pedal a few more times, hold it down and crack the bleeder. Then you have to pump it up again. Hope this helps.
Jason
Old Dec 14, 2003 | 07:40 AM
ede's Avatar
ede
the gm method is to do a gravity bleed, let the slave hang at a 45* angle. never worked for me, never could get it to bleed liek brakes do. only thing that's ever worked for me is the pheniox injector and reverse bleed.
Old Dec 14, 2003 | 09:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you got it as an assembly from GM, it's already bled. Just put it on and leave it alone, there's nothing you're going to be able to do to improve it.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
