What clutch
Old Oct 15, 2003 | 10:39 AM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
What clutch
Guys,
Ive got my aftermarket T56 ready but now i just need a final bit of help.
As its aftermarket i know i have to buy a new cross member and shortened torque arm,have my prop shortened two inches but what i want to make sure of is that if i buy a bellhousing from a manual third gen,i can then use a McCloed or similar clutch and flywheel for a standard T5 gearboxed third gen.Can i also use and fit a standard clutch master cyl and slave cyl from the T5 manual 3rd gen??
Sorry to go on but i just need confirmation
PM
Old Oct 15, 2003 | 06:43 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
My understanding is that the whole purpose of the aftermarket T-56 is to retain the stock T-5 style bellhousing/clutch/hydros while providing T-56 strength and gearings. So yes, the T-5 parts should work.
Don't quote me on that though...I don't have experience with it as I used a GM T-56 out of a '95 TA.
Old Oct 15, 2003 | 08:12 PM
SteveSpohn's Avatar
With the aftermarket T-56, everything from the rear of the bellhousing front is std. T-5 equipment. The T-56 comes with an adapter plate to mate it up to the rear of the std. T-5 bellhousing, everything else forward stays the same.
Steve
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
