Flywheel help
Old Oct 15, 2003 | 01:09 PM
SteveSpohn's Avatar
Flywheel help
Need a flywheel for a 1985 Camaro with a LB9 305 TPI engine code F.
GM has two flywheels, one for H and one for G, the LB9's never came with a T-5 in 1985. Which flywheel do I need, anyone know? It needs to be 153 tooth.
Doesn't have to be GM, if you know an aftermarket number, that'll work too.
Thanks.
Steve
Old Oct 15, 2003 | 01:26 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
steve,
part # 14085720 should be the nodular lightweight GM flywheel for the 2piece rear mains, 153 tooth 12.75" flywheel.
Old Oct 15, 2003 | 01:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Either will fit; the G (L69) one is the lightweight. THat's probably the one you want.
Old Oct 15, 2003 | 01:44 PM
SteveSpohn's Avatar
Thanks guys, that's what I was thinking, but I wanted to confirm. I figured someone else had done it. I appreciate the help!
Steve
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
