Posi question
Old Oct 17, 2003 | 07:16 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Posi question
Okay. Here goes. When the car is cold, I can drive just fine, turn fine, posi doens't make any wierd noises. After a point, I guess the unit is nice and warm, it makes a lot of racket - whines when I turn the car, little ka-klunk noises when I let off the gas, sounds atrocious. I had the fluid changed last week, they put 90W in it, but is there some additive I need, or would a rebuild be a better bet?
Note: I was going to get a better-strength unit eventually, perhaps I might need to do that now...
Old Oct 17, 2003 | 07:46 PM
bes217's Avatar
It depends on what kind of rear end you have. Some of the posi's had to have additive added to the fluid.
Old Oct 17, 2003 | 09:42 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Oh yeah, that would help, huh...
Stock 2.73's I thunk. Limited-slip unit, whatever the GTA came with in '88.
Old Oct 17, 2003 | 09:54 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Cone type LSD's don't require the use of any additive. Only the ones with clutch disks require the additive, as necessary. Most 7 1/2" and 7 5/8" 10 bolts with factory installed LSDs that I'm aware of came with the cone type diffs.
Old Oct 20, 2003 | 01:53 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Borg-Warner 9-bolt, I thunk.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
mcgarnicle
Aug 12, 2015 04:58 PM
