Bad 2-3 shift on fresh TH350 again!!!
Old Oct 18, 2003 | 04:52 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
A buddy and I took my Iroc out for a couple of Gtech runs today with the freshly checked out TH350, new 3500 stall, and 28X13.5X15 Et streets on. The 1-2 shift was perfect and the 2-3 shift would happen until I lifted of the throttle for a bit. Same problem as I was having earlier with this trans. I ran a 12.330 at 112.02 mph with two of us in the car and lifting to make the 2-3 shift. This problem is getting annoying.
If I do a part throttle run the shifts are great all the way up.
Any suggestions?
Old Oct 19, 2003 | 09:02 AM
ede's Avatar
ede
i'm not expert, not even very knowledgeable, but try a differant modulator. there are 3, i think, and all interchange, you want one found on a th400. not sure on the color code ,but i think it's black. do a search on here and you may find more info.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
LittleFranks
Sep 17, 2015 12:22 PM
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
