1990 700r4 swap questions
Old Oct 18, 2003 | 09:10 PM
86CamaroZee's Avatar
I have a 1990 camaro that is getting a motor and transmission from an 89 iroc. Th e motor is a 350 tpi and the transmission is a 700 r4 the same transmission that is in my car. My question is on the tranmission from the 1990 the speedometer not a cable driven speedo, but an electric one, can i swap the tail shaft from this transmission to the other tranmission im putting in the car and how do i recalitrate the speedo for different rear end gears that what came stock in the car
Old Oct 18, 2003 | 09:13 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
If you want to retain the VSS speed sensor, just unbolt it and put it in the new transmission you are swapping in to the 90. It'll drop right in. You don't need to recalibrate either.
I just did a swap today, and thats all I had to do to get the VSS sensor into the new transmission. I think its like a 10mm bolt. Just unbolt it, pull it out gently, and install using the same procedure.
Old Oct 19, 2003 | 07:47 AM
does the calibration for the gear ration have to be programed into the prom, or do i need to change the reluctor wheel, to get the right speedometer reading. Also what do the two wires on the transmission plug that goes into that vss go to, does that vss make up for the one that is usually in the speedometer of the dash cluster on older f bodys.
Old Oct 19, 2003 | 08:20 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
to recalibrate,IIRC, you just change the gears in the trans, just like cable driven, they went reluctor on 4th gens and trucks
Old Oct 19, 2003 | 06:39 PM
how do i determine what gears i use, isnt there colors on them, and can you mix a red gear with a grey gear? also were would i get these other than a tranny shop? the rear im using is a 3.23 posi with 16 inch iroc wheels and i would extimate the height of the tire as being around 24-26 inches
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
