Fluid Change on a 100K+ Tranny?
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I want to upgrade my 7004r with a billiet servo, plunger, pressure valve, shift kit, etc. I have been told that changing the fluid and filter, on a tranny with a lot of miles can do more harm than good. Any ideas? Also what fluid should I use? Synthetic?
Car: Take
Engine: Your
Transmission: Pick
Go ahead and do it. If changing the fluid causes the tranny to "die", then it was on its last leg anyhow and its better to be broke down at the house, then on a 300 mile roadtrip.
Car: 1984 Pontiac Firebird
Engine: modded 5.0
Transmission: modded 700r4
don't know if this helps, but my car has 99k on it and I changed the ATF, and a week later the tranny died completely. After second gear, it slipped, wouldn't get 3 or 4, and then 1st went out so it was locked in second. Had to get it completely rebuilt. I'd say if you're gonna put all those upgrade parts on it just rebuild it now.....
on a side note during the rebuild i put in a stage 2 shift kit and i love it. It slams into the gears now.
hope this helps!:lala:
Thornburg
Aug 25, 2015 01:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
