TV cable Stuck
Old Oct 29, 2003 | 11:05 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
TV cable Stuck
Hey Guys Ive been tring to adjust my tv cable for all that im worth
but i cant get that damn little button to press in (copperish D) any suggestions or solutions greatly appreatted\
Old Oct 29, 2003 | 11:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
push in the button and pull back on the black cable, then take and slowly open your throttle wide open. You will hear a ratcheting sound as you do this. After you have opened the throttle wide open, release it and the tv cable is adjusted properly.
The Trickster!!!!!!!!!!!!!
Old Oct 30, 2003 | 03:20 AM
RJR99SS's Avatar
the buttons can be a little tricky.
Usually i just get a pair of curved channel locks, put one jaw on the backside of the housing, one on the button and squeeze ever so slightly.
Old Oct 30, 2003 | 11:51 AM
RJR I've Tried that but never at the same time as pulling the Cable is that why i cant do it right im such a newb some times
Old Oct 30, 2003 | 12:48 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Some TV cables do NOT ratchet and must be adjusted manually. This is tricky becuase there has to be the right amount of tension on them.
The first TV cable I bought from NAPA did not adjust by ratcheting. I returned it and bought one from GM just so I could be sure it was setup right.
Do yourself a favor if you have a non-ratcheting TV cable. Go to your local GM dealer and get one from them. Its about $40, but well worth it.
Old Oct 30, 2003 | 06:32 PM
Im just not sure im pressing the button down hard enough ...it doesnt feel like its moving but im pressing for all the life of me
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
tmellott89
Oct 14, 2015 02:06 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
