Lightweight Flywheel, 383, street/auto-x/drag
Old Oct 31, 2003 | 01:30 AM
danzig27's Avatar
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
I'm in the process of building a 383. I'm trying to get it to put out around 450-500 ft/lbs. I want to be able to do alot of everything, auto-x, drag, and still be daily driver. I've been reading the other posts about lightweight flywheels and i agree that for drag you need more inertia off the line. But for Auto-x you'd be better of with a lighter one. Now my problem, is that i would like something in the middle. Something that will help get the revs up quicker. But do you think that a lightweight one would bog me down with the amount of torque that i'm looking at making? Is there a decent flywheel out there that is not super lightweight, and still less than stock? I had heard that aluminum had a problem of the heat causing it to expand or what not, and that was creating problems. Please help me decide what to do. Thank you!
Justin
Old Oct 31, 2003 | 07:26 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i have a GMPP nodular flywheel, it is a little less weight than stock.
LT1Formula
Oct 8, 2015 08:34 PM
mfp189
Sep 27, 2015 09:25 AM
