2600 stall too much?
Old Nov 2, 2003 | 02:44 PM
TorchTA's Avatar
ACT 2600 9.5" converter....
too much for the stock L98? Not enough?
lol...more importantly, how will it help the 1/4mile times?
opinions/comments?
-JT
Old Nov 2, 2003 | 05:18 PM
MdFormula350's Avatar
This is what slp says about their 2400 stall.
Torque Converter, Lock-Up 1986-91 Vette/1985-94 Camaro/Firebird (2400)
These 298mm (11.73") diameter torque converters are designed to improve low speed (bottom end) performance while still retaining the lock-up features of the stock converter. By raising the stall speed to approximately 2400 RPM the engine is in its power band sooner. Zero to 60 and 1/4 mile performance times are reduced as much as 2 to 3 tenths. Driveability improves with little or no effect on fuel economy depending on your driving style.
Our converters feature fully brazed pump fins and high capacity Torrington thrust bearings for durability and are fully balanced. They are completely compatible with the TPI Computer in your car and require no modifications for installation. We recommend this converter for use with rear gears up to 3.73. With any high stall converter a transmission cooler is recommended.
http://www.slponline.com/view_produc...RTNUMBER=60100
Old Nov 3, 2003 | 04:29 AM
TorchTA's Avatar
And that translates out to what exactly?
-JT
Old Nov 3, 2003 | 07:27 AM
bigals87z28's Avatar
Car: Check The Sig
yeah your fine. I plan on a 2600 for my 305 after i get this dam zz4 cam put in... too dam lazy to tear apart the whole engine... i have more fun just driving it then fixing it...
Old Nov 3, 2003 | 08:52 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I think a 2600 stall will be fine for your car. The street use should remain pretty much the same. It should help out your launch on the track provided you can hook.
Old Nov 3, 2003 | 01:01 PM
88 IROC BOB's Avatar
If the L98 is stock heads and cam it is too much. I tried a Vig 2800 two years ago. Ended up selling it and put the stock back in.
I would keep it no more than 2400.
Bob
Old Nov 3, 2003 | 06:44 PM
TorchTA's Avatar
yup. stock heads and cam.
for the moment.
may spray the car later.
-JT
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
