help with my Drivetrain....
Old Nov 4, 2003 | 11:20 PM
camaro_91's Avatar
Car: 91 Camaro RS
Engine: just put in 305 building a 406 ci
Transmission: 700 R-4
help with traction......
I own a 1991 camaro RS and i have a SB 400 ci 4 bolt main with
.30 flat top pistons, a small cam, world sports men II heads
2.02" in and 1.60" exh stock corvett 4 bbl intake, and a 4 bbl edelbrock carb.
im haveing traction problems
i have a 1986 z28 rear end i dont know what size gears it has and a 700 R4 trany and i cant stop the tires form burnig out i can burn threw all 4 gears if i dont let off the gas help me....
i need help with what rear end and what size of gears i should get also, suspension up grades and a better tire
any feed back will help :hail: Thanks
Old Nov 5, 2003 | 12:45 AM
Opha's Avatar
im sure alot of ppl with some decent power can burn through all gears, hell i've redlined till top of second until i let off just to lay a fun patch. but that's not the problem, you need the magical thing called traction. Power is nothing with out traction, hell i can build a 3,000 hp engine and drop it in a civic and it would do no good if i couldnt get that power to the groud.
look for suspension up grades and a better tire, mostly a street slick. for suspension talk to spohn about what you need. i dont know much about that stuff really, although i will be doing my suspension build up this winter.
Old Nov 7, 2003 | 11:07 AM
camaro_91's Avatar
Car: 91 Camaro RS
help with traction
Who is spohn, and how can i reach him
thanks....
Old Nov 7, 2003 | 12:58 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
See the ad at the top of the page --> http://www.spohn.net/
His username is SteveSpohn
