Replacing clutch, dropping axle?
Old Nov 8, 2003 | 05:19 PM
92RSSlowmaro's Avatar
Is it really nessecary to remove the coil dampeners and torque arm in order to drop the rear axle when pulling the tranny back to replace the clutch?
Old Nov 8, 2003 | 05:25 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
No, just unhook the torque arm bracket on the tranny. If you have your jackstands under the frame ahead of the rear LCA's you can then push the arm up out of the way by hand.
Pete
Old Nov 11, 2003 | 07:53 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Agreed. There's no reason to drop the torque arm....just take it loose at the front and let it swing up against the floorpan.
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
mizz0313
Aug 12, 2015 06:45 AM
rsrmoore
Aug 7, 2015 08:44 PM
