700-r4 delay in 2-3 shift
Car: 1990 IROC
Transmission: TH700-R4
the 700-r4 in my 90 has a problem where it will hold in second gear and delay shifting in to third when the trans is cold. the delay becomes less as the trans warms up. i know the 700's have a problem with the 2-3 shift as my old 86 would not shift into 3rd at WOT. the 90 also has a similar problem where it will once again delay the 2-3 shift at WOT ie. it will sit at 5000 rpms for a good second just revving before it shifts into 3rd. anyone know if a good old transgo kit will fix this or is my trans on its way out?
had this same problem with my 700r4. i drained the fluid and added a new filter and royal purple trans fuild. no problems anymore. it may be your trans fluid has lost its life, not the tranny. i thought id try this before getting some tranny work done and it worked. hope this helps
