pick-up tranny into Camaro?
Car: 1988 Oldsmobile Cutlass
Engine: 307 V-8
Transmission: 200-4R
Will a TH-350 tranny from a 1986 Chevy pickup go into a 1982 Camaro? The Camaro has a 3-speed automatic, so I assume it's a TH-350. Will I have to make any mods to the tranny or Camaro frame? The reason I'm swapping transmissions is because this pickup transmission only has about 20 miles on a rebuild. Plus I wathced it be rebuilt, so I know it's legit.
Thanks for your help
Car: 2002 Formula Firebird
Transmission: 4l60e
82 Camaro could have a 2004r in it. It is also a 3 speed.
The th350 will fit without mods to the frame or anything. BUT you need a new driveshaft, crossmember, and either a new torque arm or a b&m change over kit.
If your car has either a 2004r or a th350 your driveshaft should work. You will still need to do something about the torque arm and crossmember.
Hope this helped.
Hope this helped.
Car: 1989 C4
Axle/Gears: 307
The 200c is almost identical to a TH350. Your driveshaft fits and the crossmember fits. The only things you will have to do is hook up a vacuum line and buy a kit for your tq arm. The swap is direct except for the tq arm and the selector peice on the transmission which can be swaped from your 200c.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
