Gear set and 26 vs 28 spline ????
Old Nov 23, 2003 | 04:02 PM
Drakar's Avatar
I am potentially picking up a 4th gen rear that will require a rebuild, but it is complete. the only damage is 2 teeth from the carrier are missing (haven't had it professional inspected yet don't know what else is toast)
I know it potentially will require a complete rebuild if not a partial.
I would like to know if my gearset and carrier will transfer over from my current rear (85 26 spline 3.73 non posi drum rear 100% stock)
I also want to know where the 26 spline vs 28 spline axels come into play?? I have no clue how a rear works, and I would like to know if it is the carrier that is the diff between axels as I looked on Richmond's sit and all the care about is 2 series or 3 series. From what I read I think I have a 3 series but, with the axel difference would I need to replace that???
Any help is appreciated.
Old Nov 23, 2003 | 04:40 PM
ede's Avatar
ede
there are no teeth on the carrier. the carrier from a thirdgen will swap over but the axle length is differant. 89 was the transition year from 26 and 28 spline axles, they fit in a splined hole in the carreir so the axles have to match the carrier. most likely the 4th gen rear has a couple of teeth off the ring gear if so you can swap your gear set over, as long as the same series carriers are used.
Old Nov 23, 2003 | 04:55 PM
Drakar's Avatar
ok, thx for the explaination
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
