Rearend Gears
Old Nov 27, 2003 | 10:14 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: 700 R4
Rearend Gears
I have a 1986 Camaro with 2...somethings in the rear! Do i need anything other then the gears to put 3.73 in the rear?? In summit it says i need to change something is this true and what is it? Thanks!
Old Nov 27, 2003 | 10:35 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
Yes and no. You have whats known as a 2 series carrier. To run a 3.73 you would need to change to a 3 series carrier because the ring gear offset is different. If you have an open diff or your posi is dead, now is a great time to toss in a new posi since you have to change it anyway. But, if you can afford the new carrier, some companies are making 3.73's that fit your 2 series carrier. I dont know what I think of these yet. But when I switched from my 2.80-something open diff, I just swapped in a brand new posi 3 series with my 3.73.
This pic will show you what I'm talking about. The 3.73 gears for the 2 series carriers are considerably thicker to make up for the different offest, and this just seems a little sketchy to me.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
