Torque converters
Old Nov 28, 2003 | 08:36 AM
assassinx1's Avatar
Car: 92 Camaro RS
Transmission: 700 R4
Torque converters
hi i was wondering if any one had any tips on putting a higher stal speed torque converter on a stock set up ...if so hiw hard s it to take an installed torque converter out of he trans.....
Old Nov 28, 2003 | 09:30 AM
ede's Avatar
ede
weights around 40 pounds or so, pulls right out of the trans no bolts or anything holding it in, not hard at all.
Old Nov 28, 2003 | 10:43 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
To make it easier on yourself... it should be a two man job with a floor jack to lower the tranny. Get the car up in the air and completely disconnect the tranny including the four bolts on the converter to flywheel. Drop the trans to the ground, enough to remove the converter and simply pull off. The new one is pushed on while rotating until it settles in place with 3 clicks. By the way, this is a messy job, the old converter holds a fair amount of fluid. Have fun!
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
