just want to be sure about rear end
Old Nov 30, 2003 | 01:33 PM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
Hey all whats up? Well another question, I have a 91 RS, and its the stock rear end in her. I want to know if it will hold up to a 360 horse, 375 ft lbs torque engine. My tranny is built well, and im told by many a people that it doesn't lose that 25% everyone seems to agree with so im thinking 290-300 hp to the rear. I have heard that the rear can take up to about 310 horses.
Now, if it can't, what is a cheap alternative to fixing the problem and making sure that it won't bust out on me when I decide to give my baby a little hell?
Just so ya know, this isn't a strip car, its just my daily driver, with a lil bit o ***** behind it to have some fun every once in a while.
Thanks!!!
Old Nov 30, 2003 | 04:08 PM
ede's Avatar
ede
depends a lot on how you apply it and if you've doen anything to strengthen the rear
Old Nov 30, 2003 | 04:47 PM
x_wolf's Avatar
Car: 91 Camaro RS
nopers, as said its stock. If there is something I could do to strengthen it, what would it be? I am really hopin this sucker don't die on me, thats more money then I really can spend cheers and thanks
Old Nov 30, 2003 | 07:25 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
if you put an relatively sticky tires on it, you can kiss it good bye. im putting in a zexel torsen and 3.73s from slp. im also going to weld the axle tubes to the carrier and get a good cover. hopefully itll hold up to the 305 with drag radials
Old Nov 30, 2003 | 08:16 PM
joshwilson3's Avatar
Old Nov 30, 2003 | 09:49 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
bad wording, what i meant was the housing
Old Dec 1, 2003 | 02:11 PM
x_wolf's Avatar
Car: 91 Camaro RS
I've always been told that this isn't a good idea. So I won't do it, is there anything else that could strengthen the rear up? What about new gears? or would that just make it worse?
cheers!
Old Dec 1, 2003 | 02:14 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I think there are quite a few guys putting alot more power than that to their stock 10 bolt. If you don't run ET-Streets or similar you shouldn't have much trouble.
x_wolf's Avatar
Car: 91 Camaro RS
would replacing the differential unit do that? I am looking at what you had talked about on the SLP site, the t/o zexel torsen differential.....says it'll fit right in and its only 99 bucks??
ok thanks!
Old Dec 2, 2003 | 09:38 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
the 99$ posi is a take-off 4th gen posi. They are sorta strong but the HD zexel torsion posi is much stronger. Its quiet a bit more $$ thought. However a new 99$ zexel torsion holds up to 4th gens fine.
I know a guy running a 02 trans am auto with his stock rear fine...only mods are a slp catback....oh and about 150hp shot of nitrous. He spins 1/2 way down the 1/8 mile track and still runs 7.7s. Its crazy.
Old Dec 2, 2003 | 11:28 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Well, my 10 bolt with GM 3.73 gears lasted me eight years of street driving, Autocross and Hillclimbing. I don't Drag Race. Finally a Pinion tooth fatique cracked and sheared off.
Last time car was on a Chassis Dyno it put out 330 HP at the rear wheels and 360 Ft\lbs of torque. Since that test several changes have been made and we're probably close to 350 RWHP.
So...Yes they can last. YMMV.
Old Dec 2, 2003 | 01:36 PM
x_wolf's Avatar
Car: 91 Camaro RS
dude you aint losing that much through your drivetrain. Thats nuts! you gotta be puttin more then that down, specially with a stick! Nice car!
Old Dec 2, 2003 | 05:03 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
It's been quite a while since the car was on the chassis dyno. Since then several improvements have been made to the engine. Goin' on the Dyno again this spring. Thanks for the thumbs up
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
