Weld axle tubes with rear still in car?
Old Dec 3, 2003 | 10:21 AM
25THRSS's Avatar
Can it be done, better yet, should it be done?
Old Dec 3, 2003 | 10:58 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I did mine this way in the car when I fragged the second rear end. I went through on both tubes and tacked a 1/2" on four sides of each tube then proceeded by stitch welding one tube for an inch or so, jumped over to the other tube and did the same, back to the first tube opposite of the bead I just laid, so on and so forth. Might have been a little too cautious on my part, but after this mod and the new diff cover with preload bolts I blew out this new rear in a 1/4 of the time that my other ones lasted. Coul've been streesed ring gear or soemthing, but after this lastest episode I'm never installing a 7.5" under my car ever again. Gettin tired of chaging rears only to implode them again and again weak little bastards anyways.
Old Dec 3, 2003 | 11:20 AM
ede's Avatar
ede
i'd pull the cover and drain it first, shouldn't have any problems
Old Dec 3, 2003 | 12:51 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i would criss-cross across the tube so it does go out of wack from the heating, but people that do it all the time told me that was just overly cautious..... *shrug*
im probly going to be doing mine this weekend if i weld the SFCs in...
Old Dec 3, 2003 | 01:54 PM
25THRSS's Avatar
cool, let me know how it goes. I'm going to be doing a bunch of rear end work very soon. I've got 3.42's and an eaton posi going in as well.
Old Dec 3, 2003 | 02:03 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
hopefully, if all goes well, i can just say i did it and have nothing else to report... if i have to say somthing otherwise, then somthing went wrong..
my only question on it is, i wonder if i can have the axle tube on jackstands when i weld it?... but im just going to stick the stand under the chassis, so it hangs.. just to be sure... heh.
Old Dec 3, 2003 | 02:55 PM
ede's Avatar
ede
mr dude i'd say you aren't wrong to do it your way, but i tend to agree with "everyone" you are being a bit to careful.
Old Dec 3, 2003 | 02:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol, i dont hear that too often.
im not in a shop getting paid by commission so im not to worried.....
im almost considering printing that out and framing it on the wall...
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
draco
Oct 4, 2015 09:25 PM
mizz0313
Aug 12, 2015 06:45 AM
