26 or 28 spline
Old Dec 10, 2003 | 02:35 AM
SeanTimothy's Avatar
26 or 28 spline
ok so ...i have a 86 camaro --parts car-- and my 91 rs.
i see a few deals on ebay for 26 spline , posi with 3.73s, around 150-200 dollars for both....BUT thats only for the 26 spline there are no posi units + gears combo deal for 28
what im asking here is, whats the diff between 26 and 28. IF i find a deal that costs lets say...30 dollars more for the 28 spline posi and gears, is the 28 spline a better rear to use? or are they both about the same rear end? help me out here fellas
Old Dec 10, 2003 | 07:23 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I had a similar problem when I bought a new Locker for my 87 T/A and it was a 28 spline and my car was a 26. I called Moser and they told me that I had to have axles made to make the carrier fit etc. If I were you, I would call them up and get some info from them, they are very happy to answer your questions and help you out.
http://www.moserengineering.com/
Old Dec 10, 2003 | 12:27 PM
well this posi unit is supposedly from a fourth gen fbody i believe.
what i ment to ask was, ....which should i use, the 26 or 28 spline...i have one of both....and how much of a difference is it between 26 and 28??
Old Dec 10, 2003 | 01:29 PM
CamaroX84's Avatar
A 28 spline axle is larger in diameter than a 26 spline, so if you have both, use the 28.
Old Dec 10, 2003 | 02:06 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
26 or 28 spline axle shafts have to have matching ID splines in whatever carrier you plan on using. Can not be mixing parts it will not work.
Old Dec 10, 2003 | 06:39 PM
CamaroX84's Avatar
Yeah sorry I forgot to add that...the axles will not physically fit if the spline count is off.
Old Dec 10, 2003 | 08:12 PM
i know you cant mix 26 spline with a 28 spline carrier, what im saying here is, i have a choise to use either axels....i can get a 26 or 28 spline posi carrier.....and i have 26 AND 28 spline axels...
Old Dec 10, 2003 | 08:24 PM
DJP87Z28's Avatar
Use the 28 splines axle shafts if you have matching parts. The higher the spline count the more contact and stronger part.
Old Dec 11, 2003 | 12:20 AM
i figured as much.....but how much stronger......itd be easier for me to use the 86 cause i can take my time installing the gears......but if the 28 is a good bit stronger...ill use the 28 and suffer not having a car for a couple days....
Old Dec 11, 2003 | 09:20 AM
DJP87Z28's Avatar
The 28 spline shafts were upgraded in 1989 and in all future 3rd & 4th Gen cars. If you want use the OLD style 26 shafts go ahead and use them, why drag this Post out any longer.
Old Dec 11, 2003 | 09:32 AM
because no one ever answered the initial question ...HOW much stronger is the 26 vrs the 28!!!!!!!! what are the major differences other than the spline count!!!! was better material used to make the 89+ axels? heh!
Old Dec 11, 2003 | 10:18 AM
DJP87Z28's Avatar
codeysabatini
Nov 10, 2015 04:07 PM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Numbah-1
Sep 20, 2015 09:31 AM
Prodigious
Sep 18, 2015 05:23 AM
