TH350 vs TH400
Old Dec 16, 2003 | 05:02 PM
roadracinGTA's Avatar
TH350 vs TH400
I am trying to decide between a TH350 and TH400 trans. I have heard that 400's absorb more power. With the technology available I would think that the internal components are equally as strong in both. I have pretty much decided on a unit built by HUGHES. I am also planning on buying the competition model w/ upgraded sprag and drum.
Old Dec 16, 2003 | 09:03 PM
EvilCartman's Avatar
Car: '82 Z28
Probably get away with running the TH350, less weight, less power loss. If you want something that you don't have to worry about, the TH400 would be your best bet. Mikes Transmission builds some awesome transmissions and I've heard Hughes are pretty good too. How much power are you going to be running through it?
Old Dec 17, 2003 | 09:14 AM
planning on 500 at the tires or more. Stock 350 w/ procharger destroyed the TH700 very quickly. Now I have a 383 w/ most everything on the engine upgraded.
Old Dec 17, 2003 | 09:47 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
with a name like 'roadracinGTA' why would you want an auto
Old Dec 17, 2003 | 10:09 AM
don't want to spend the time converting to 6spd. Also not really streat legal any more so just want to set it up for drag racing right now. Eventually I will road race it w/ a gear vendors OD
Old Dec 17, 2003 | 11:06 AM
pskel350's Avatar
normally for roadracing you want a stick....
my buddy used to have a TH400 behind his 406, it ended up balloning the stall converter. then he put in a TH350 and it has done really well behind a 400 rwhp car. we could not tell a difference in power between the two trannies, but no track times really.
darwinprice
17
Oct 11, 2015 11:51 PM
romcjr
Sep 17, 2015 05:18 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
89newfun
Sep 16, 2015 09:28 AM
WickedBowtie
Sep 11, 2015 11:24 PM
