Need a 700r4 expert fast!
Old Dec 20, 2003 | 03:13 PM
Steve-o's Avatar
I have a 57 Nomad with a TPI motor and an early 700r4. I have a Dakato Digital dash also. My speedo suddenly quite so I removed the cable driven VSS and found that the driven gear was no longer a gear at all--it has no teeth. What would cause this? If I just replace the gear will the next do the same thing? And more importantly where did the plastic teeth go when they got sheared off. Will this cause a transmission problem? Thanks for the help.
Steve
Old Dec 20, 2003 | 07:00 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
This isn't uncommon. The plastic the gear is made from becomes brittle with age and exposure to oil. Good job GM.
The bits probably wound up in the trans filter. I would drop the pan and service the trans (filter and fluid). This should prevent any damage. Even if they did find their way into the trans internals they probably wouldn't do any harm because the plastic would just get ground up into bits, but fluid and a filter are cheap...
djmarch
Oct 2, 2015 10:41 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
