Harsh, hesitant shifting...
Old Dec 21, 2003 | 05:30 PM
CbrasTsteLkChk's Avatar
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
My trans shifts very late and when i'm runnin it up slowly it shifts rather harshly, mostly from 1st to 2nd and 2nd to 3rd. When i run it up really quick, though, it's still harsh but not as noticeable. What gives? Anyone....???
- New gaskets in between the valve body
- Cleaned out valve body very well
- Cleaned separator plate very well
- New servo piston spring
- Loosened throttle kick down linkage
- Took throttel kick down linkage OFF completely
- Replaced Governor
What the hell gives? I've checked EVERYTHING
Maybe if i flushed the trans real well that might help?
Old Dec 21, 2003 | 07:16 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
if it's a 700r4 from an 82-85 camaro, i know there have been several technical service bullitens from GM about harsh 1-2 shifts. something with the accumulator and spring.
the tranny in my iroc has a pretty firm 1-2 shift, it's the original tranny and i'm pretty sure it hasn't been messed with.
Old Dec 21, 2003 | 08:44 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Have you checked the fluid level? Low fluid level will definitely cause this.
Old Dec 21, 2003 | 09:20 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
Have you checked the detent cable? Any throttle body work lately? It sounds like it might be out of adjustment.
Old Dec 22, 2003 | 09:57 PM
Yeah fluid level has always been fine... and clean. And When i dropped the entire valve body i replaced the accumulator spring bc the original one in there was broken in pieces.
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
