Just a few quick ???
Old Dec 30, 2003 | 12:30 PM
jdrafke's Avatar
Hi well i got a 700r4 with a 2600 stall. Just wondering i dont hit overdrive till about 55-60mph is this normal? I have 2.77 gears in the back(yes,they suck!). Also in overdrive if im goin at like 30-35 mph and let off the gas the rpms shoot down real fast. Im wondering if this is a sprag problem or is it normal cuz the stall is higher? Also, u guys think the 2.77s with the 2500 stall is really hurting me i want to get it changed but im not sure what to do first, that or headers.
Old Dec 30, 2003 | 12:32 PM
jdrafke's Avatar
jsut an add in the shooting down of rpms is mostly in overdrive. if im goin like 45+ it will wind down slow for a secodn or so and then shoot down. If the converter locks at about 65 it winds down fine till it unlocks. DO i got a prob here? THeir is plenty of engien braking in 1st, 2nd and a bit in 3rd. Sorry if this sounds dumb jsut curious it only has 8k on it and a big hayden tranny cooler on it
Old Dec 30, 2003 | 09:44 PM
jdrafke's Avatar
ttt
Old Dec 31, 2003 | 02:26 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The rear gears really aren't well matched to that converter. You'd be a lot happier with 3.42s or 3.73s.
Given your rear gear that not shifting into 4th until 60MPH seems normal. The RPM loss is most likely because it is a looser converter (higher stall). I don't think anything's wrong.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
