Manual guys read this please.
Old Dec 30, 2003 | 12:51 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Im changing to T56 at the moment.Im using T5 bellhousing ,pedals and master/slave cylinder.Can any of you take a pic of your set up to show me how and where it all fits together.
thanks
PM
Old Dec 30, 2003 | 01:58 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I don't think you can use the stock t5 bellhousing with a GM t56.
Old Dec 30, 2003 | 02:06 PM
powermite's Avatar
Car: Transam
Its OK im fitting a new aftermarket T56 with T5 bellhousing,original lightweight chevy flywheel,McLoed Clutch,Spohn shortened torque arm,cross member plus ive shortened my prop 2".Just need to see how the T5 assembly fits together
PM
Old Dec 30, 2003 | 08:20 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Bolt the T5 bellhousing to the block, just like always. Use the adapter plate to rotate the transmission mounting pattern from slanted to straight-up. Then just bolt the T56 to the adpater plate straight up.
The Spohn crossmemeber and torque arm should just bolt up like the stock pieces. The torque arm mount will now be on the crossmember, so the one on the T56 isn't necessary.
Old Dec 31, 2003 | 02:15 PM
Z_Ghost's Avatar
I can try to take a pic later today when I start to pull the trans out to check the pilot bearing.
Old Dec 31, 2003 | 09:21 PM
Z_Ghost's Avatar
Sorry no go on the pics, I tried to take a pic but they will not come out.
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
Street Lethal
Aug 14, 2015 08:25 PM
mizz0313
Aug 12, 2015 06:45 AM
