I have been hunting a vibration for sometime now and I seem to have found it.
I pulled the driveshaft and ran the car in gear, vibration.
Pulled the trans out and put the empty T-5 case in the car, vibration.
Pulled the case, bellhousing and the clutch, no vibration.
It’s so smooth that I knew as soon as I started the car up that the vibration was gone.
Now here is the question, what’s the problem?
Aftermarket T-56, ZZ4 with a GM flywheel (16lb nodular iron), Centerforce dull friction clutch, pressure plate and throwout bearing for the T-5. They are all new parts and the pressure plate and flywheel look good, no hot spots and both are flat.
I did find this, but the pressure plate does not have a yellow dot on it and it’s about the 4thgen clutch and I am running the thirdgen clutch.
http://128bitencrypted.com/centerfor...s/I94GM004.pdf
i guess you could call a machine shop and ask em if they would compare the balance of your flywheel with a known good one....
ZZ4 is a two piece main with a external balaced flywheel right? perhaps the off balance is "wrong"?
The ZZ4 is one piece main seal and uses the same flywheel as all the one-piece motors.
Besides with just the flywheel on the motor it's really smooth, it's just with the clutch and pressure plate on there that it's vibrating.
TKOPerformance
close
- Join DateDec 2003
- LocationNewark, DE
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car'86 Camaro, '02 WRX, '87 K5, '67
- Engine350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
- TransmissionT56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
- Axle/Gears3.73, 3.90, 4.88, 3.55, 3.54, 7.00
- Liked:1 Time in 1 Post
The clutch assembly is out of balance. I'd see if a machine shop can balance it. If they can't I'd send it back and demand a replacement.
Quote:
That's probable what I will do, still it's brand new and it's not cheep so it should not need that done to it. Originally posted by TKOPerformance
Thanks for the reply
