Park/lock control cable
Old Jan 2, 2004 | 02:05 AM
steve's Z28's Avatar
I own a 91 Chevy Camaro Z28 with a 4L60 automatic trans.. I want to find out what the purpose is for the for the park/lock control cable. I was glancing at it on the Helm Camaro Service Manual. Your response is greatly appreciated. Thank you.
Old Jan 2, 2004 | 03:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It prevents the shifter from being taken out of park while the ignition is locked.
Old Jan 3, 2004 | 12:39 PM
loose shifter lever
Ok, thank you for the info. Now, my problem is a loose shift lever. In Park, there is 1/4" of play no tightness. On the other gears I have to fish around to get them in the proper gear. In reverse for example, I shift it back with difficulty and once it is there the car is in reverse and I have to push the lever forward to get the reverse lights to come on. I have done some searching and it was the shift lever cable. Could a deteriorated shifter cable do this? I also have another question about the shifter cable replacing procedures. I am looking at a 1991 Helm Camaro Service Manual and it says I have to rotate shift lever clockwise to park detent and then back to neutral. Does it mean, in Park, rotate handle clockwise? Your response is greatly appreciated.
Old Jan 3, 2004 | 06:57 PM
Ok I found the problem. It was two bolts holding the shifter cable. One of them was loose and the other fell off. I had the trans fluid and filter change almost two years ago. I guess the tech didn't tighten it enough. Is it true that a person has to retighten the trans pan bolts after 100 miles after the change? Another question I have is how much play(movement) should the shifter have in each gear? If there should be no movement, how do I tighten it up?
Old Oct 26, 2011 | 02:58 PM
Black'87 T/A's Avatar
Car: 1987 Trans Am
Engine: 355, carb
Re: Park/lock control cable
yea im having a similar problem, right now i bought a new ignition switch for my 87 trans am and i removed the old one, and removed the park/lock control cable, but the new one that i bought comes with a new one on the switch, so how do i remove the old one from the cable so i can put it on the new switch, thanks, or should i just mount the old cable holder on the new switch?
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
