TH400 Wt
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
TH400 Wt
What's the wt difference between a short tailshaft and long tailshaft TH400?
Also, any idea what the difference in wt between their output shafts is? Just trying to calculate difference in rotational mass on this one.
What would be the wt difference between a stock 12 inch converter vs a Vigilante 9.5 inch unit? Probably the difference here would be fluid capacity.
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Originally posted by ede
not much on the trans on the TCs i'd guess 20-30 pounds. what differance does it really make? neither trans or TC are selected on weight, or at least weight alone.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
wouldnt the benifit of weight loss from using a shorter tailshaft be offset by the weight gain in the rotational mass of the driveshaft?
i realize you went to a alum one, but say, if you were comapring a alum one to a alum one....
darwinprice
17
Oct 11, 2015 11:51 PM
five7kid
Mar 1, 2001 02:28 PM
