Trans Brakes, What Are They And Their Purpose
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
I was reading a jegs magazine and i come up trans brakes, what are they and what are their purpose in the tranny, i got a 700r4
Car: 4
Engine: 6
Transmission: 5
They shift the trans into 2 gears at the same time, which thereby locks it up solid. 1st and some other gear (usually reverse but it varies with trans model) To launch, it lets off the other gear. It allows you to fully load the motor into the converter without burning anything up except the fluid, and then lets it take off without shifting into a gear to do so.
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The motor isn't as important as the trans, converter, rear gear, tires, and rear suspension setup. If you have a stock motor backed by a built trans with a high stall converter hooked to a built rear with slicks and a tuned suspension then you could very well need a trans brake on a stock motor to get the most out of the car.
A trans brake is like dumping the clutch on a stick car.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
To add to it You say you have a 700R4.... Ive never even seen a Transbrake for a 700r4... I would not like the chances of a 700r4 holding up with a transbrake even if they did make one...
1992 Trans Am
May 10, 2023 07:19 PM
