T5 / WC T5 tail housing
Old Jan 2, 2004 | 09:09 AM
coprunr's Avatar
Car: 89 S10 Blazer
Engine: 4.3
did a search no answers found.....will a T5 tailhousing work on a WC T5? i am going to do a V8 swap into a S15 pickup and i want to use a WCT5 ...need to know if the T5 tailhousing will work...i know the S10 T5 tail housing will fit a regular T5...but will it interchange to a WCT5 ? ....
Old Jan 2, 2004 | 03:06 PM
coprunr's Avatar
Car: 89 S10 Blazer
Engine: 4.3
nobody knows if a T5 tail housing is the same as a WCT5 tailhousing?
Old Jan 2, 2004 | 03:33 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I've got one here and they appear to be the same.
Old Jan 2, 2004 | 09:14 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes, I took the one from my v6 apparently none WC and put it on a WC v8 trans (the v8 one had the upper clamp bolt hole striped out) I did not look at the v6 very well untill yesterday and it is a none wc and I know the v8 was a wc as I had to fix it before.
3rdgenparts
May 21, 2016 11:50 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
