Pro-Built 700R4 w/ Lockup Kit
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Does anybody know if Pro-Built Automatics 700R4 Street/Strip transmission comes with the 4 gear pressure switch and self grounding solenoid already installed in them? I need to hook up a lockup switch kit, but do I just need the External wiring or both Internal and external? The Internal kit is the 4th gear pressure switch and grounding solenoid. I'm hoping that when they build these tranny they already have them install, so the only thing I will need to do is wire the external parts.
Thanks: DTL
Thanks: DTL
Transmission: 4L80E/4L80E
When you order it, tell Dana that's the way you want it.
Dragonsys
Sep 25, 2015 03:51 PM
Eric-86sc
Aug 24, 2015 09:01 PM
