Best gear ratio for TPI
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah, more information needed.
Engine? Modifications? Trans? Converter(if applicable)? Type of Driving? Daily Driven (Y/N)? Post back and I'll try to gelp you out.
I'll throw a data point up for you...mine liked 3.42 gears.
I was running a Vigilante torque converter stalling at 2600-2800rpm, an Accel intake base, and ported stock runners. Cam was a GM HOT.
13.2sec @ 102mph in the 1/4mile, 287hp/363tq on the dyno.
as a rule for most street type preformance applications 3:42 is pretty much what everyone goes with. you should provide a bit more info though so you'll get a better or more thought out answer.
3.42 or 3.73.
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Sanjay
Aug 12, 2015 03:41 PM
