Workability of aftermarket auto shifters
Old Jan 8, 2004 | 12:39 PM
N/A89CamaroRS's Avatar
Car: 89 Camaro RS
Engine: LO3
Transmission: 700-R4
Ok, so I'm getting into searching for drivetrain parts and I was looking at auto shifters. Anyone care to enlighten me as to how these work? Does it turn your car somewhat into a manumatic? I am going to get a shift improver kit at the same time and I don't want to do anything wrong, I heard that manually shifting an auto was bad for the tranny. So if anone could explain how these work to me I would be much obliged. Thanks a lot!
Nick
Old Jan 28, 2004 | 06:58 PM
Car: 89 Camaro RS
Engine: LO3
I have to bring this back from the dead because I really need to know, I'm looking at the Hurst Dual-Gate shifter or the B&M Hammer shifter with a shift kit, need to know ASAP!
Old Jan 28, 2004 | 07:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The shifter can't change the way the transmission shifts. That is, if you take a stock shifter and put it in OD and drive the car, and you take an aftermarket one and put it in OD, you won't be able to tell the difference. Or, if you shift the one manually from 1st to 2nd and so on, the trans will shift identically to how it will shift with the other.
Mostly they improve the driver feel for what gear the trans is in, and/or prevents the shifter from moving more than one gear at a time. That allows you to just slap it up one gear and not have to worry about it going into neutral or whatever. It allows for much greater consistency at the track.
J-money
Jan 4, 2019 09:45 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
88rscamar0
Sep 23, 2015 09:08 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Fronzizzle
Sep 8, 2015 12:10 PM
