converter recomendations
Old Jan 11, 2004 | 03:29 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I wanted to get some stall recomendations, I am getting ready to get my 700r4 rebuilt. It is a 90 5.7, T.P.I. , Crane 2032 cam (270/276 advertised duration 452/465 lift) 1.52 Comp roller tip rockers, l.t. headers, 3.23 rear gears (posi). The trans will have a shift kit and Corvette servo, I figure about 2500 stall, due to the gearing and T.P.I. which I am sticking with both. It is my daily driver, but I do drag race it at the track about three times a month. 2500 sound about right?
Old Jan 12, 2004 | 12:26 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah, 2,500 is good. Any more and you'd need a taller rear gear. You probably want to consider ported or AM heads soon, and an intake upgrade.
Old Jan 12, 2004 | 12:37 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
ya that would be just fine.. i run a 2400 with my setup and its fine
Old Jan 14, 2004 | 03:52 PM
CamaroX84's Avatar
I had a setup just about identical to yours (stock TPI, same cam, same rear gear) and I ran a 2200 stall. I pulled 1.89 60' times while spinning the slicks (stock suspension at that time). Just something to consider.
Old Jan 14, 2004 | 05:19 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
[hijacking the thread]
does anybody know the stall speed of converter from 4.3 V6 if it's installed in mild 350?
[/hijacking the thread]
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
