Want to put electric speedo in...
Old Jan 11, 2004 | 11:42 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Hey guys i want to convert my whole dash over to Autometer Ultra lite gauges and want to put a 120mph electric speedo in. now since my car has a cable, how hard is it goin to be to put the electric set up in? Autometer sells the adapotor kit thingy to convert from the cable on thetranny to electric, but im not sure how well it will work or if it will work. i also have a th350 tranny just incase anyone needs to know.
so has anyone done this and gotten good/great results?
Old Jan 11, 2004 | 11:51 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
If you want to go straight electric, you could use a late (TH350-C) tailhousing (it uses the same sealing o-ring location as the 700-R4,) a 700-R4 (like a 1991 third gen) electric VSS (which is still gear driven) and run the wiring from the tailhousing to your dash. Depending on what access you have to salvage yards, this could be easy.
That's certainly not the only way to do it, but I thought I'd throw out that approach.
Old Jan 13, 2004 | 11:00 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
anyone eles? i kinda want to do this simple becuz i dont want to mess with tailshaft housings.
Old Jan 13, 2004 | 11:34 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The Autometer sender works great. I ran one in the M21 in my old Nova for a while. It's the same part for your TH350 I think.
The Autometer speedo isn't designed to read of a 3rd gen VSS, so if you use stock 3rd gen VSS you'll need a buffer box. It's cheaper to just use the Autometer sender.
Old Jan 13, 2004 | 11:50 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
cool , so the autometer sending unit go where the cable would go on the trans housing?
Old Jan 13, 2004 | 11:52 PM
That's right. Everything else is wiring.
Old Jan 14, 2004 | 12:23 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
cool thanks, i just hope i dont screw anything up, havent done alot of wireing yet but have watched a friend do alot and he's a ASE master tech and he loves wiring **** up.
Old Jan 14, 2004 | 09:39 AM
The best advice I can give is solder all your connections, and then shrink tube them, or use the self bonding tape like the stuff Edelbrock sells.
Crimp connectors are easy, but can vibrate loose over time, and are also prone to corrosion. Also, most commercially available crimping pliers have the wrong dies. They just crimp the connector into an oval. This isn't the right way to crimp them!
Old Jan 14, 2004 | 07:10 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah i was plannin on soldering every thing and using the srink wrap. i just gotta get some butane for my solderin pen and solder wire. ive soldered stuff before but it was mostly pipe, i dont think it will be that ard for me, i think the hard part will be running all the wires.
Jorlain
Aug 24, 2022 05:11 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
beachrodder
Aug 7, 2015 04:27 PM
