355/th350
Old Jan 16, 2004 | 11:30 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
355/th350
i just got offered a 355 and th350, i was wondering if they will slip right in place of the current lg4/200c..will the current drive shaft be the correct length? anything else i need to worry about?
Old Jan 16, 2004 | 12:13 PM
ede's Avatar
ede
drive shaft isn't a big deal, they can be made longer or shorter. it'll bolt right up
Old Jan 16, 2004 | 05:47 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
the stock ds will fit as long as the th350 has the right (6" i think) tail housing, if not, a driveline shop should be able to shorten it for under 50 or lengthen it for under 100.
Old Jan 23, 2004 | 03:39 PM
Kev_89_Iroc_Z's Avatar
Car: 2000 z24, 1989 iroc-z
Engine: 5.7 tune port changed to carburetor
Transmission: th700r4 soon to be th 350
it'll bolt up no problem but u'll need a trans swap kit to change the th700r4 to a th350 hurst has a kit #500001 and ur drive shaft will be all rigth if the th350 has a 9" tail housing if it comes with a 6" housing u could probley get away with a driver shaft from an older camaro.
Old Jan 25, 2004 | 12:00 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
you can just bolt the new stuff in and not worry about any swap kit. my car had the 200c in it and one of the owners before me put a th350 in it with no problem or swap kit and this was about 10-12 yrs ago now.
Old Jan 25, 2004 | 12:39 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
where is the torque arm mounted at?
Old Jan 25, 2004 | 01:35 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
tranny
Camrs89
Mid-West Region
Nov 25, 2009 01:11 PM
Camrs89
Nov 14, 2009 09:58 AM
montecarlossman
Aug 20, 2009 09:30 AM
T-rocZ88
Jan 10, 2007 06:42 PM
Soule88SC
Sep 7, 2006 11:02 PM
