Auto Tranny Experts
Old Jan 22, 2004 | 03:13 PM
Chevyguy1984's Avatar
Auto Tranny Experts
I've got a mint rebuilt 700R4 tranny out of an 86 corvette. I've also got a dead 700R4 out of an 87 V-6 camaro. The corvette trans uses a shorter output shaft and tailshaft housing which has no provision for a standard tranny mount. Can I swap the standard length output shaft and tailhousing out of the camaro tranny into the vette tranny? Thanks.
Old Jan 22, 2004 | 03:49 PM
Bob86ZZ4's Avatar
I don't have an answer for you, sorry. But, don't toss that output shaft housing away. They are valuable to Corvette people. If you need to get rid of it check with the local Vette club and I'm sure somebody would take it off your hands. Or take it to your favorite tranny shop and they would love to have it on their shelf I would think.
Old Jan 29, 2004 | 04:28 PM
Thanks, thats good info to know. Does anyone know if the output shaft and tailhousing is compatible?
Old Jan 29, 2004 | 05:43 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
the tailhousing i think is... just use some silicone around the 4 bolts to assure no leaks, i had to swap min too cause one of them didnt have the chassie bar support...
you may have to swap speedo gears too depending on the different rear ends
Old Jan 29, 2004 | 10:26 PM
MCas7's Avatar
The tailshaft housing will fit, but in order to swap the output shaft, you have to take the whole transmission apart. It isn't as easy as just swapping it out. If that is what you had planned on, then yes, they will swap.
Old Jan 29, 2004 | 11:29 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Even if its not what you planned on, it'll still swap..
To swap the output shaft you do indeed have to take most of the trans apart, but its not TOO bad of a process (certainly less difficult than a complete rebuild).. You just take out the major rotating pieces as assemblies (no need to disassemble the clutch packs or anything)... Would be a nice time to install a good shift kit while you have the valve body off as well (also when you're not upside down under your car later wondering where that checkball rolled off to )...
Old Jan 30, 2004 | 08:19 AM
Thanks very much I was worried that this tranny would be no good to me. I was counting on fully diassembling it anyways so its no biggy, thanks again.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
djmarch
Oct 2, 2015 10:41 PM
