LT1 Flywheel
Old Jan 25, 2004 | 12:09 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
LT1 Flywheel
Simple question, will a standard thirdgen clutch pressure plate bolt to an LT1 flywheel?
Old Jan 25, 2004 | 01:00 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Not very likely, but you can use a normal 86-92 flywheel on a LT1
Old Jan 25, 2004 | 09:55 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Well its the opposite situation, After some recent motor problems, a friend offered to sell me a L98 short block. My current motor is a pre 86 two piece RMS. He happens to have an LT1 flywheel since my current one won't bolt up to a 1 piece RMS. I just wasn't sure if my current clutch would bolt up to the LT1 flywheel or if I needed to find a normal 86-92 flywheel. Thanks.
Old Jan 25, 2004 | 10:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well, the clutch for the T-56 LT1 won't bolt to a T-5 flywheel; so I'd suspect the T-5 clutch won't bolt to a T-56 flywheel either.
Old Jan 25, 2004 | 10:40 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The extra depth of the LT1 flywheel will keep this idea of T5 clutch on LT1 flywheel from working properly.
part of the reason for that is the hub of the disc is facing forward instead of back towards the tranny.
There is a pressure plate which is shallower in depth which would probably allow the T5 f-body disc, and LT1 wheel to work if the LT1 flywheel has the same bolt pattern as the T5 flywheel, but the PP pressure is not sufficient for a V8 f-body, and that's all I'm saying.
Old Jan 25, 2004 | 11:47 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Well that being the case I guess it won't work. Thanks alot guys.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
