advice on a one wheelpeel
I have a 1990 firebrd with a l03 and 273 open rearend.I don't have money for a swap just yet.I was wondering what I can do to put more power to the ground right now?Any tricks? I have gotten both wheels to spin before,mainly in a good spot on the asphalt.
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
LCA drop brackets, or other suspension mods.
I'd go with the Lower Control arms and maybe an alum driveshaft, saves rotational mass and are getting cheaper/easier to find I just scored a 3" LS1 shaft for 75 bucks! Also when I put an msd 6A box in out of the light felt a little nicer. You could go over your bushings and replace the worn ones with poly as well
Originally posted by dankhound
Isnt the ls1 shaft a different lenth? Dont you need an lt1 shaft?
Engine: 305 TPI (LB9)
Transmission: WC T-5
Originally posted by conlinj
nope perfect fit it's 3" rather then 2.75" for the 1LE shaft and lighter by half a pound, and has a factory balancer, supposed to be the best balanced factory shaft
it did wonders for my RS, pulls to 100+ with virtually no vibration. Trending Topics
Yeah, just don't ever have to turn and you'll be fine : )
Car: 4
Engine: 6
Transmission: 5
As far as putting power to the ground, an aluminum drive shaft is basically zero bang for the $$$$ with a stock L03 drive train. Total waste of money.
What you need is a posi and some gears.
Go to the junkyard and find yourself a 90-up rear end out of a 5-speed 6-cyl Camaro or Firebird, MAKE SURE it's 90-up, so you get the 28-spline axles. It should have 3.42 gears. Then put the $99 SLP posi in it.
That will cost about the same as an aluminum driveshaft, and you'll get a 3.42 posi out of it. Huge improvement in the car, instead of something you probably won't even notice.
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
if all you wanna do is spin the tires, go ahead and get the 4.11 & installation kit while slp has em on clearence, then youll do alot of peeling, but top out rather fast
HoosierinWA
Oct 7, 2015 10:15 AM
