Will my diff hold up?
Old Jan 29, 2004 | 05:49 AM
JaysZee's Avatar
Car: 91 Z28
Engine: 5.7L
I'm thinking about picking up a set of strip only wheels and tires. Probably 15x3.5 Weld Draglites for the front and 15x10 Weld Draglites with 26x15x11.5 M/T ET Streets for the rear. My question is can my 7.625" 10 bolt diff handle it? The diff girdle should help but I don't know. Thanks
Old Jan 29, 2004 | 06:12 AM
ede's Avatar
ede
yeah welding the tubes and a girddle will help out a lot.
Old Jan 30, 2004 | 02:28 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
You've already got the good 28 spline axels. The girlde will help a lot, but now your weak spot will be either the side gears of the gearset. At your power level you may be okay, but then again on slicks it could easily break. Traction is what kills rears, not horsepower.
Old Feb 1, 2004 | 11:31 AM
JaysZee's Avatar
Car: 91 Z28
Engine: 5.7L
It's not so much the HP that worries me but the Torque and Traction.
Old Feb 1, 2004 | 07:47 PM
matts90firebird's Avatar
I would not launch at the track too hard
baby her at the line
mattcanty
Oct 12, 2015 11:08 AM
racereese
Oct 3, 2015 03:46 PM
