TV Cable help
Old Jan 30, 2004 | 01:36 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
TV Cable help
My cousin has a 4l60E automatic in his trans am and his transmission seems to slip in third gear, he has to let off the gas for a bit for it to catch it. How does one adjust the tv cable and could this be the cause of this? Thanks.
Old Jan 30, 2004 | 08:01 AM
Bandit5's Avatar
It sounds like the TV cable is not set correctly and is not opening the throttle valve enough for it to **** into higher gears.
Use this guide... it explains it better than I can: https://www.thirdgen.org/newdesign/tech/detent.shtml
Old Feb 1, 2004 | 04:27 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Kind of hard to adjust a TV cable that doesn't exist...
a 4l60e is electronically controlled
Old Feb 1, 2004 | 05:02 PM
Bandit5's Avatar
... one track mind... always thinking 3rd gen.
Old Feb 1, 2004 | 07:19 PM
thirdgen88's Avatar
Car: 1995 Corvette
I hear ya!
Old Feb 2, 2004 | 12:27 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
LMAO
Old Feb 2, 2004 | 02:25 PM
kd5boc's Avatar
Car: 92 RS
I was thinking the same thing...but someone beat me to it LOL.
Since it is computer controlled, the pressure is regulated from the ECM, and that is controlled by a TPS on his throttle body. You can adjust the TPS as you would a TV cable.
Have him loosen the TPS and move it one way or the other. If it moves right when you go to WOT, then move the TPS to the left just a bit. Not much...but enough so that the slipping goes away.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
