lockup
Old Jan 29, 2004 | 08:14 PM
84350camaro's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 355
Transmission: TH350
Axle/Gears: 3.08
lockup
Ok building a 700-R4 for non computerized, carbed engine, now how do i get a lockup torque converter to lockup since i dont have a computer to control it?
Old Jan 29, 2004 | 11:36 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There are several ways to set it up.. Try a search on "lockup" and you'll find lots of useful threads... The easiest way would probably be to wire it up with a relay and a manual switch..
Old Jan 30, 2004 | 08:03 AM
Bandit5's Avatar
Just use a simple toggle switch, I am gonna do the same thing.
Use this guide... VERY simple to do: https://www.thirdgen.org/newdesign/t...ueswitch.shtml
Old Jan 31, 2004 | 02:33 PM
joenycfbody's Avatar
Car: 81 Camaro
Engine: 406w/TPI & Serpentine belt setup
Transmission: 700R4 & 3.42 Posi
TCI, B&M, and a company in california called bowtieoverdrives all make kits to lockup the converter in non-computer controlled cars. Very simple to install.. I have the kit from www.bowtieoverdrives.com.
All range from $75 - $125.
Old Feb 2, 2004 | 12:46 PM
Engine: 355
Transmission: TH350
Axle/Gears: 3.08
thanx!
Old Feb 2, 2004 | 02:32 PM
kd5boc's Avatar
Car: 92 RS
Mind you...this ONLY works if the tranny and computer are still connected! If not, then just run the wire from terminal "A" on the tranny.
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
illegal87
Mar 29, 2001 07:38 AM
